Question about Canon EOS 40D Digital Camera
I am attempting to use "Eye-Fi" connect /x2 with my canon 5d. Since my camera accepts CF cards I am using the SDHC EYE-FI card in a SD/SDHC CF ADAPTER. (SDCF-01). When I insert the SDGC Eye-Fi card into the adapter and load ithem into my 5D, the camera first seems not to be reading the card and then gives message, "Card not formatted". When I attempt to format the card in my 5D, I get the message "Cannot format card". I formatted the card in my computer and again tried to use it but the messages from my 5D remains the same. HELP!!!!! I have a big shoot of Graduates in two days time and plan to use this medium to display portraits on my Laptop for selection. KARL ANDERSON
Posted by andersonk on
Paul Green
    Prodigy:
    An expert who has answered 500 questions.
  • Canon Expert
  • 527 Answers
You need to use the card reader the came with the Eye - Fi card as this has some sort of code in it that runs when the Eye-Fi card is inserted
Posted on Sep 23, 2017
5 Related Answers
Anonymous
SOURCE: CF error
My canon xti had the same reading cf card error 99.
Since my camera is out of warranty. I had to find a way to fix it. After reading all possible solutions in this site, I looked at the pins (that used to connect to the CF card) and found out that one pin in the middle bent. That caused the problem. I used the tiny screw driver to bend that pin back to the original position. Inserted the card back and it worked. I felt so happy!!!! (Please make sure to have the battery removed while fixing...to be saved.)
Posted on Jul 05, 2008
Anonymous
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
robmcd27
Rob
  • 423 Answers
SOURCE: canon 5d cannot format cf care
Hi there, did you check the card itself? SD cards have a locking switch on the side. Move the switch from locked to unlocked. Put it back in the camera and see if that helps.
Rob
Posted on Mar 02, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: CF Card is not formatting. When I try to format
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see the following: http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Posted on Jul 19, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
How to connect coolpix s6300 to ipad via wifi
Your camera does not have a build in WiFi transmitter. You could use a Eye-Fi or Transcend WiFi memory card for connecting it wireless to the iPad, iPhone (or Android device). I'm using a 16 Gbyte Class 10 Transcend WiFi card in my Nikon and it works great on both my iPhone 4 and iPad 4 gen. I think now the 16 GB will cost about 40 dollars, because they now also have a 32 Gbyte WiFi card.
Both Transcend and EyeFi have free apps on the Apple and Android App store.
When you put an WiFi card in your camera, enable the use of the card as described on page 84 of the manual. You only have to install the free app and read the manual, but I'm convinced you have the connection up and running in no time.
The Transcend card is about half the price, has twice the memory card speed and twice the capacity of the Eye-Fi card. And it also transfers RAW pictures (You can't view them on the iPad, but you could transmit them to your PC, using the network) Only the X2 SDHC 8GB of Eye-Fi can transfer RAW.
Jul 02, 2014 | Office Equipment & Supplies
Tip
How do I Connect my Non-Wireless Camera to a Wireless Network
<p>Your digital camera can store images via a wireless network uses SD cards for memory storage. Special cards are available from SD Eye-Fi and also under the Lexar brand with Eye-Fi software, rather than just a flash memory, Wi-Fi radio that can connect to a local network and send your photos your computer contains. The SD card requires some special configuration and installation on your computer, but it transfers the files stored by the camera directly to your computer without further intervention. <br /> <p><br /> <p>1. Insert the Eye-Fi card in USB reader that came with it. Connect it to a USB port on your computer. If this is the first time you installed the Eye-Fi, the computer recognizes the new device and install the software and start automatically. If the software was previously installed, it will start automatically. <br /> <p><br /> <p>2. Register a new account or log in with your Eye-Fi account with your email and password. <br /> <p><br /> <p>3. Click the Eye-Fi for a firmware update if the exclamation mark symbol is placed. <br /> <p><br /> <p>4. Select your local network from the Network drop-down list. Enter your password and click "Add a network card." <br /> <p><br /> <p>5. Select "I do not want to set up online photo sharing and now" and click "Next." Some cards do not see this screen. <br /> <p><br /> <p>6. Remove the card when the display "Complete" and insert the card into the camera. <br /> <p><br /> <p>7. Take pictures and look for the wireless transmission on the computer. <br />
on Aug 05, 2011 | Cameras
Eye fi memory cards always reads full
hello try to format with active partition manager v3 (free )
May 02, 2014 | Eye-Fi 4CN 4 GB Class 6 SDHC Wireless...
I do not know how to transfer pictures from my Olympus SZ-14 to my ipad.
Because your camera uses SD cards, (SD/SDHC/SDXC and Eye-Fi) you have several options. The easiest and fastest possibility is to use a camera connection kit. On the picture the two on the left. The most left for iPad 1 to 3 (30 pins) the right for all anther iPads. Be aware these won't work on the iPhone or iPod. Then on the right is a WiFi card. Can be bought from Eye-Fi Transcend (Cheaper and much faster) and SanDisk. But more firms are bringing this item.
The Wi-Fi card is slower, because it is using the card as a hotspot. and the the fastest Wi-Fi is always slower than wired. The Transcend card, I also use to put the pictures on my iPhone, using Wi-Fi. he card has even more possibilities, like sending pictures direct to a computer, but you can check this on the sites from Eye-Fi and Transcend.
Both solutions can be the same in price, because when buying a Wi-Fi card, you also have a new memory card (Class 10 in case of the Transcend)
Feb 01, 2014 | Olympus Cameras
I cannot upload my photo to my face book
your connection msy be slow try doing it from your friends house
Nov 03, 2013 | Digi Eye-Fi Share Video Wi-Fi Wireless 4GB...
Canon ixus 220 HS card compatibility
The IXUS 220 HS can use any SD/SDHC/SDXC, Eye-Fi, MultiMediaCard, MMCplus, or HC MMCplus card.
Apr 07, 2012 | Canon Cameras
My casio ex-zr100 camera is new out of the box. I put an Eye-Fi 8GB explore/X2 memory card in and received a Card Error message. Any advice?
Your camera is certainly compatible with SDHC cards and even with the next SDXC cards which will soon be available, so that's not the problem.
You either have a faulty camera or a faulty SDHC card, and as the latter is a generic no-name brand I'd suspect that before the camera.
Try the card out in other SDHC compliant devices, and also see whether you can borrow other SDHC cards to try in your camera to isolate where the fault lies.
Whichever item is faulty cannot be repaired by you anyway, so return the offending item for a refund or exchange. If the card is faulty, then I'd strongly suggest just getting a refund and replacing it with a good quality brand as they will guarantee the performance of their products and give full after-sales support.
Aug 02, 2011 | Casio EXILIM EX-ZR100 Digital Camera
Can i download pictures to my computer
Yes you can most certainly can :)
For European markets Nikon include NikonView 6.2, while in certain other markets the new PictureProject software is included, you can set this to automaticly import pictures when the camera is plugged into your computer.
the other options would be to remove the sd card from the camera and use a card reader
or another clever option is an "eye-fi" card, this will automaticly transfer pictures to an account when you are within range of an open wifi network
(see here for more info http://uk.eye.fi/)
Mar 06, 2011 | Nikon N70 35mm SLR Camera
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
Easy way to upload photos on facebook
Well before trying to upload photos in your facebook account, copy all the pictures form the memory card and save them in your pc...this will make easier to upload pictures on facebook
Jun 09, 2010 | Digi Eye-Fi Share Video Wi-Fi Wireless 4GB...
Canon EOS 40D Digital Camera Logo
1,027 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
