SOURCE: Opened dryer door mid-cycle left open 1 hr. Dryer won't restart
there is a door switch on left upper corner of drier opening, make sure the little prong is clicking when you push it in. this turns the drier back on when the door is closed and the start button is pushed.
SOURCE: My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
SOURCE: my kenmore 80 series dryer won't heat but
Had similiar problem once and it turned out to be one leg of the 240 volt
supply was dead. The drum motor only needs one leg (120V) to run, but the Heating elements require both legs (240v). Make sure you have 240V at the recep.
SOURCE: Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
SOURCE: I own a Frigidaire electric dryer model no.
Hello
The beeping sound means that it is the thermostat that needs replacement. This thermostat is located inside the back cover panel on the blower wheel housing towards the exhaust duct. This problem can be solved once the thermostat is replaced, you can also test the thermostat with a ohm meter, you can check its continuity. Please get back to me if you have any other questions.
Kevin
If
your dryer
is not drying
like it once did or if you just have not taken the time to give
yourself a clean
dryer
in a long time then you need to do that. At least once a year the
dryer
cleaning
should take place. Lint
build up
in the dryer
duct
is one of the main causes for your dryer to fail.
Here is the
rest of this tip about Dryer
Maintenance
heatman101
