The display blinks AD and all the lights are flashing
The "Ad" in the display indicates that the dryer is in the Auto Dry cycle.
The dryer will run in the Auto Dry cycle until the moisture sensor bars detect no more moisture in the garments being dried. The machine will then go into a cool down period and then end the cycle.
If the dryer is getting unusually hot, I recommend checking for a restriction in the air flow. Make sure that your lint screen is properly cleaned before starting every cycle. Check the flexible vent hose behind the dryer for a kink or a restriction. Check the exhaust ducting to the outside of the house for lint build-up or a restriction. This may help the dryer perform properly.
SOURCE: Error code on dryer display
Check your breakers. Mine was doing the same thing, all of the 120v parts of the machine were working. (blower/drum motor/ lights) However the element wasn't coming on. Went to the breaker and found that one side of the 2 pole breaker was tripped. Turned both off and back on. Heater started working again.
When you set the dryer on settings such as normal or permanent press, it engages the various sensors that help the dryer to make the most efficient use of energy. Moisture sensor, heat sensor etc. (THAT IS WHAT TURNS ON YOUR AD SETTING) Normally it selects a time based on factory settings that it believes your load should be dried by. Say 50 minutes at Normal (high heat, normal) Every so often during the cycle, the machine will check the humidity sensor and the other sensors and try to see if the dryer is still on schedule. Sometimes it will determine that more time is needed, occasionally less time. While it calculates, it displays the Ad meaning that the machine is on auto dry. TO TURN OFF AUTO DRY, set it to a time setting instead of a DESCRIPTION setting.
SOURCE: My Frigidaire dryer has an error code of AD and is
Hi
Thanks for
using FixYa. Error code AD means air/auto dry. This
type of dryer has no thermo fuse which is a fuse like part that tends to break
disengaging the heating element, there for the dryer has a busted heating element,
you’ll need to replace it then it should be good to go. Normally runs parts and
labor about 150. Please do accept the solution if the issue is
resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
SOURCE: what does Ad code mean on front load dryer
AD is not an error code i found this out by goin to the frigidaire web site it just means that the dryer is in auto dry mode.
