SOURCE: indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
SOURCE: Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
SOURCE: indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
SOURCE: Indesit D61D Sticks In Its Cycle
The repair can be done yourself you need to first purchas a can of liquid wrench with extention. and first shut off power or disconnect power. there is a acess panal that you need to remove to get at gears to grease once it is greased you will need to turn the dial a couple of times (powerless) and replace the panel and plug or turn on power (when you are turning the knob besure to return to the start cycle ) if you need more info please email me [email protected] thank you and good luck
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element
Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan
Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat
Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
