SOURCE: Battery and Charger problems
Hello
Thank you for using FixYa for your problem
Can you check the charger is outputing the correct amount of voltage, (power surge maybe)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
SOURCE: my Asus S6F laptop battery wont charge it sits on ...
1)Reason:
a.The battery has no voltage.
b.There is problem with charger,
as it has no output electric current.
c.Low charging efficiency due to
external cause.
2)Solutions:
a.Test whether the charger has voltage and
output electric current or not.
b.Check if the charger is well contacted with
battery.
c.Activate the battery with voltage and current 1.5 time higher then
the highest ones of battery. (Use this method only when the battery can't be
charged.)
come from laptop battery site:http://www.buy-battery.ca/faq.htm
SOURCE: i have a dell inspiron
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
Testimonial: "thanks. thats worked. will i have to use a dell battery or can a compatible one be found"
SOURCE: i have a dell inspiron 1545. i have the charger
yes plaese buy a dell battery.. for further details you can visit the following site
support.dell.com
Testimonial: "cheers :)"
Your battery is dying and needs to be replaced - Are you sure it's not replaceable? If you can provide me with the model number I can check for you.
