20 Most Recent ASUS Eee PC T101MT-EU27-BK Convertible Tablet Questions & Answers
2answers
How to change inverter on an asus t101mt netbook
Check the manufacturer website for you model laptop - verify if it's not an LED screen. If it is then you'll need to replace the screen - LED screens don't need an inverter.
11/14/2018 3:00:35 PM • ASUS Eee PC... • Answered on Nov 14, 2018
My battery do not keep any charge, but its
"plugged in, not charging" could a symptom of incompatibility between the charger and the battery.If this is the case, once you unplug your ASUS ac adapter, the laptop goes off.Anyway, it's still Ok to use the charger but you need to plug it in all the time.Here is a little trick that I found that works.1. Power up the Notebook with the battery installed,if you can.2. Turn the computer completely off and remove the battery.3. Power up the Notebook with AC power only (no battery installed).4. Turn the computer completely off and re-install the battery.5. Power up the Notebook.6. The message no longer appears (at least for me it has disappeared).
8/14/2013 8:22:34 PM • ASUS Eee PC... • Answered on Aug 14, 2013
Download and install asus 10.1 password reset
can you do a restore. if not it need to be takeing to best buy to have pass word reset
7/8/2013 11:36:18 PM • ASUS Eee PC... • Answered on Jul 08, 2013
Screen freezes , mostly when on line
I, you have to many process open. 2, You have Malware or a Virus. Download these two programs and use often: 1, MALWAREBYTES freeware at: http://www.filehippo.com/download_malwarebytes_anti_malware/, UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL SCAN, DELETE ALL RESULTS, Reboot. 2, CCLEANER at : http://www.filehippo.com/download_ccleaner/ This will clean the junk from your machine. In the TOOLS section, STARTUP, Disable ALL unnessary startup programs, In the Internet Explorer tab, disable ALL TOOLBARS they are killers on broswer speed. The idea is to get rid of the excess baggage you aquire over time. Take a look at these tips: http://www.pcmag.com/article2/0,2817,2364937,00.asp
12/23/2012 6:07:46 PM • ASUS Eee PC... • Answered on Dec 23, 2012
2answers
Wd 11 error code:0xc0000034
The last line of your error message contains the solution: "You'll need to use the recovery tools on your installation media. If you don't have any installation media (like a disk or USB device), contact your system administrator or PC manufacturer." Translation: Start up from the disk that came with your laptop and follow repair tool instructions (or contact the manufacturer to obtain a copy - which you may possibly need to purchase. If you are not under warranty this will possibly be at a reduced cost.) Look for a label on the bottom of your pc for a phone number for service if your equipment is not useable. Good luck!
7/21/2022 8:42:08 AM • ASUS Eee... • Answered on Jul 21, 2022
Keys all mixed up keyboard
check using the onscreen keyboard or you can also check with an external keyboard to see if the same issue occurs with those. if it does the issue could be a software related. you can go to device manager, under keyboards uninstall the Keyboard Device and restart the computer.
10/7/2019 8:44:22 AM • ASUS Eee... • Answered on Oct 07, 2019
2answers
I recently purchased an Asus
Hello Machatsiduba, It's likely that the network card is capturing some radio signals phones close to your geographical location. Specifically, the Wi-Fi controller can cause this problem; I recommend you follow these links to solve this problem. 1) https://support.microsoft.com/en-us/help/4000460/windows-10-check-wi-fi-drivers-settings 2) https://support.microsoft.com/en-us/help/4000461/windows-10-wifi-problems-home-layout
5/25/2019 12:13:46 AM • ASUS Eee... • Answered on May 25, 2019
Rog 750 g750jw serial location
x2. the ASUS box has a white sticker on the new box. clearly showing this fact. the motherboard, has sticker to ,for the same thing, same answer, in the BIOS info screens, the serial will bet there and a UUID, serial, that Microsoft uses, to block activation. there a mAC too. you did not say why you need this, so lacking context we guess. omg a gaming laptop... ASUS Rog 750 g750jw on laptops in general, its on the bottom of the case on some remove the battery pack and its a sticker inside there. on newer laptops, the deleted stickers (deemed ugly) so is deep hidden. BIOS pages are it. i look at your mobo, and see only stickers on the ram slots so open the ram hatch and look? I SEE ONLY THIS. i redacted it a bit, to make it neutered. PN: not this. PT? i guess not. lower right, side is my guess, on SN. 69N-bla bla sn-rog-lf2mtn200wr504vgnybkj5cw-1-0.jpg
11/5/2018 1:26:46 PM • ASUS Eee... • Answered on Nov 05, 2018
Call Asus support, or info could be in the manual
11/25/2017 7:53:51 PM • ASUS Eee... • Answered on Nov 25, 2017
My Asus Eee netbook keyboard will suddenly for no
see if you can find out why at this link... Asus Eee netbook freeze up Google Search
10/21/2017 1:03:24 PM • ASUS Eee... • Answered on Oct 21, 2017
I was running avast anti-virus while browsing using chrome when I tripped on the power cable and the system shut down. the next time I turned the power on, I got DISK READ ERROR OCCURRED PRESS CTRL+AL
Hello, Weird problem... situation may have nothing to do with what happened. Your hard drive may have core problems. I would run the BIOS diagnostics if able. Also, boot from the OS install DVD and get to a command prompt where you can run CHKDSK. Good Luck, Steve I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
9/30/2017 3:58:53 PM • ASUS Eee... • Answered on Sep 30, 2017
0answers
Asus keyboard typing * instead of p
one or more keys may be stuck
10/25/2016 1:28:01 PM • ASUS Eee... • Answered on Oct 25, 2016
Can't enable wi-fi on Asus x43u laptop
Usually the wireless problem comes with asus laptop when you do not update the wireless driver properly. so you need to go ahead and updated the wireless driver and then you need to reboot your computer. finally your computer will start working fine. for more information you can visit : Tech Support For Asus
9/19/2016 8:29:50 PM • ASUS Eee... • Answered on Sep 19, 2016
Lost net work adapter and Internet connection
get model number and operating system and download network adapter and Wi fi adapter drivers .Then install on p.c. https://www.asus.com/support/Download/45/7/0/1/POi1J7z06m5LfgvC/41/
9/2/2016 10:35:49 PM • ASUS Eee... • Answered on Sep 02, 2016
0answers
ASUS Eee PC T101MT-EU27-BK Convertible Tablet Logo
Popular Tags
9 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
battery not keep any charge but its
  • Computers & Internet
