SOURCE: LG 42LC2S - Remote control code
After many months trying to find the BT Vision code for my LG 32LC2D, i have just had success with 005 remembering to enter an additional zero after the remote has flashed three times, so you enter 0005.
Hope it works, good luck!
SOURCE: RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
SOURCE: tv code
The Innovage Jumbo remote control manual does not list any TV's by the manufacturer Vision Quest, but that does not mean your TV is not compatible with another brand's control codes. I recommend using the auto-search function to see if any of the remote's TV codes work with your set.
To have the remote try each TV code it knows one at a time, follow these steps:
I hope that helps.
SOURCE: code number for phillips TV 32 PFL 5522D/05 TO
http://bt.custhelp.com/cgi-bin/bt.cfg/php/enduser/cci/bt_adp.php?p_sid=&p_faqid=9579&cat_lvl1=348&p_cv=1.348&p_cats=348
Here is the list for the 2 types of remote control Silver and Black. They both have diferent codes for the TV. Good Luck!
