I don't know whether Panasonic remote have set-up code for Vision Quest TV. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Check these codes. If you wish to get more codes, check this site. 0664 0691 1233 0529 0404 1939 0067 0586 0039
0246 248 0247 0481 1167 1938 0910 1248 0906 0895 0728 744 0736
good day if that remote you have the original on your tv , no need to search a code, code only apply when you using the universal remote. maybe your remote needs cleaning the board, so that all button will function
The Innovage Jumbo remote control manual does not list any TV's by the manufacturer Vision Quest, but that does not mean your TV is not compatible with another brand's control codes. I recommend using the auto-search function to see if any of the remote's TV codes work with your set.
To have the remote try each TV code it knows one at a time, follow these steps:
Turn on your TV.
Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
Press the TV button on the remote so that the LED blinks once and then remains solid red.
Press the ON/OFF button slowly and repeatedly until
the TV turns off. The LED will blink once each time you press the
ON/OFF button.
Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
