SOURCE: give me the solution for my canon image runner 2520 photocopier which shows error code e000002?
Well try this method unplug for 30 second and plug it back push start and off button at the same time and hold it for 10 second and let it go then try to text copy and see if it work
Good luck
SOURCE: Error code is coming in my machine
Dear
To enter service mode
1) Press the User Mode key.
2) Press 2 and 8 on the keypad at the same time.
3) Press the User Mode key on the control panel.
Then press COPIER>FUNCTION>ENGIN>ERRCLEAR.
And make power OFF and ON.
If not solved..
1.Check connection of the Connectors (Thermistor Connector
and AC Connector).
2.Replace the Fixing Main Thermistor (Film Unit).
3.Replace the Fixing Assembly.
4.Replace the DC Controller PCB
Hope this may help you to get clear.
Thanks.
