Mind does the same thing, I'm not sure if it has to do with age or if it is time for new timer! mine does finish it's cycle, and wash's and rinses the cloths, does Yours? and it only does this in between wash and rinse cycle! The noise You hear is the timer making it's way through cycle, as I said I think it has to do with age, and in the future, hopefully a long ways into the future, the timer will need replaced! If This does this when You first start wash, then You may not be getting water into Your washer, Do you use city water or well?
SOURCE: programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
SOURCE: Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
SOURCE: Indesit WA6x washing m - dial clicking around...
This sort of problem is usually associated with a faulty control board
If there is a reset point on the timer, then reset it, and try again, if it still does the same thing, then it it is going to be the control board.
Testimonial: "thanks - good to know even if notgood news."
SOURCE: washing machine stopped between rinse and spin
This could be either one of two things, and that is that you have a bad cycle timer, or a bad water pump. Either would give you the humming noise that you are hearing.
