SOURCE: i have a motorola H350
Sounds like you need to do another method of connecting your phone to your unit, heres the trick..
Most phones have multiple methods of installing your headset, you can either connect it, or activate an existing connection, and last SEARCH.
If you have installed this unit already, all you need to do is ADD another device, when you find your settings for blue tooth, its as simple as TURN ON CONNECTIVITY, and your phone will find the device, if you stored it already on your phone.
Another step is to do a reboot of your headset, hold down the call button until your headset light turns on and turns colors, keep holding the button down 5-10 seconds and you will see it, then try to connect your mobile phone to your unit by SEARCHING for DEVICES in your phone settings.
Last but not least, you can search the internet for the headset, download the PDF and pray that this simple solution can assist you. Motorola's website is very user friendly and has a search engine similar to google or yahoo, register your headset while you are there, because you can get it replaced, exchanged, and have warranties with ALL new units purchased, or if you purchased a used unit from a local store, you still have a limited warranty you can use to get a new or repaired unit.
I hope this helps..
PLEASE RATE ME!
ManOwar
SOURCE: 14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
SOURCE: motorola h715 been connected to the charger for
my H715 motorola bluetooth headset mute is on and I can't turn it OFF! HELP!
SOURCE: They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
SOURCE: Hi, fitted my scooter with two brand new 40 amp hr
What type and what voltage were the old batteries removed from the scooter?
Testimonial: "Thank you for the help, - the link didn't work but i'm slowly getting to understand things now."
