Hi, after connecting H350 to computer via USB to charge; light faintly hovers blue before becoming full strength, seems as it charges for less than a minute before light turns off and does not appear again unless I disconnect the unit and reconnect it. What is happening and how can I fix it?
SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
SOURCE: Motorola H350 bluetooth headset light indications, what do they suggest?
try pin # 0000 and when its fully charged the blue lite will go out
SOURCE: MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
open and, replace the rechargeable batteries
