I tried pull it 1000x i took out my spark plug cleaned checked has a nice gap 'looks good' i i took of the carburetor cover i sprayed starting fluid i turn on for a couple second. i dont know how choke. works full choke 1/2 3/4 full 1/4 . do i leave idle/ running lever down or up maybe the middle , i want it to start.. should i get a a new spark
An engine needs compression, timing, an adequate spark and the right amount of fuel in order to start and run.
When attempting to diagnose trouble each one of those requirements must be checked in a fairly logical sequence and when all are present the engine will start. If the engine doesn't start and run then one or more of those requirements is absent.
A new spark plug correctly gapped wouldn't do any harm at all but as it fires using an ether spray it would indicate a lack of fuel is the problem.
The correct operation of the choke if it is a strangler type should be observable by looking down the carburettor bore.
