Televison & Video Logo
LAUREN BOURLIER Posted on Mar 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LCD screen is white, dim picture and sound works fine
Denkichu
Level 3:
Master:
  • Master 507 Answers
  • Posted on Mar 02, 2017
Denkichu
Master
Level 3:
Master:
Answers
507
Questions
0
Helped
111643
Points
1471
Seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Have thin line of picture on right side of screen, rest is blank. Sound is fine
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Sound ok white screen no picture
- Flickering screen
- Dim screen
- Slow start
1helpful
Tv problem troubleshooting screen all white no picture
- Flickering screen
- Dim screen
- Slow start
I have a 46 inch LCD LN46A630. It was working fine and suddenly the screen when white. You can faintly see a picture beneath the white screen. I spoke with someone from Samsung that directed me to
It sounds that its main digital board has damaged. Video processor section has the fault. It has no repair at component level. Should be replaced as card basis. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Pull up older posts there.
1helpful
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
LCD screen and small viewfinder screen go snowy than white. When I turn the camera on the LCD worked fine, when I than turn it, it was just white. Now it won't even turn on normal. I can still make...
Go to your menus, set all to factory settings or default.
Test the camera by using more of the settings, and notice how it works.
The LCD settings especially are what you want to make sure are set right...not too bright, and of course not too dim either.
1helpful
2answers
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
1helpful
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
I have the White Screen of Death
Try pressing the reset button underneath the antenna and if this doesn't help, then you'll need to have the LCD display replaced.
- Jim
SHARCNET-USA
No picture
This is most likely your Backlight on its way out. Try looking closely at the screen to see if you can still see a dim picture if so then I am 100% sure that is the fault.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
