Hmm, even the actual manual is a little confusing, it covers too many models.
It suggests if you have 2 sets of RCA's they are OUTPUT ONLY, so you can run external amps and save the units amp chips.
The external amps will come on automatically if connected correctly.
http://manual.kenwood.com/files/B64-2926-10.pdf
Full wiring diagram on page 25 :0D
SOURCE: Ipod Connection through RCA Cable
Actually, what I think gbaity is doing is utilizing his IP(Interactive Pioneer)-Bus port in the back of the DEH-P3000, which is an input port designed to allow the deck to use an external multi-disk CD changer. All you need is the CD changer, then change the input source from your deck to "M-CD". There are folks on eBay and other places that sell a cable that pluggs into that very same port. They are designed to allow the unit to accept input through the IP-Bus from an ipod or just about any low-level input that you can pass through the RCA jacks. I have the same deck, and also just purchased an ipod cable for the IP-Bus, and it also does not work. I have been told that I need to switch the "M-CD" input source to "AUX" as the input, but I do not know how to do that. pressing the input source button only displays "CD", "M-CD", and "FM/AM". Does anyone know how to add "AUX" to the choices or otherwise show us how to make these cables work? Thanks - TomR
SOURCE: aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
SOURCE: PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
SOURCE: Cannot get my mp3 player to operate on the aux input consistently
I have a 2002 Pontiac Montana and I use a 2 pronged RCA plug at one end with a yellow plug and a white plug, and the other end is one plug to use for the MP3 player. Plug your RCA plugs into the bottom 2 plugs. My RCA plugs on my cord are yellow and black the yellow one is in the middle
plug and the black in the bottom one and I use the AUX input for my MP3 player. I have a SANSA
and a Ipod and they both work fine. I hope this helps. Just a FYI so you don't think your radio is
going whacko after you do get the MP3 player to work the AUX will always come on first and you will have to push the AM/FM button on the dash or the steering wheel to get the radio or DVD back on.
And the DVD player will have to be switched on for the AUX to play the MP3 player.
Have fun...
SOURCE: Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
