Question about Car Audio & Video
My 04 yukon cd changer won't eject the cd. any advise?
Posted by fke3 on
jklisiewicz
    Sergeant:
  • 246 Answers
If you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Posted on Feb 17, 2010
Won''t eject a CD
No idea which car, which changer - next time add this info.
Most changers or radios with CD capability have a manual eject option - usually a small pinhole on the face which you can insert a paper clip to do this. HOWEVER, you should really check the owners manual before doing this.
Jan 08, 2017 | Cars & Trucks
Lincoln Continental CD changer
broke buy a new one or pry on it not to hard
May 19, 2013 | Car Audio & Video
Hi I have put a cd into the changer but now cannot eject the cd, the stereo reads error 99 please advise
The CD, when inserted, became either wedged or not seated properly and the sensors dont know how to respond. Here are the codes for Kenwood.
Changer Error Codes
• E-00: Poor Cable connection.
• E-01: Magazine not properly set in changer.
• E-02: No Disc in magazine.
• E-03: CD does not have selected track number.
• E-04: Disc is dirty, upside down or unreadable.
• E-10: No data is recorded on the MD. The player plays the next disc automatically.
• E-99: Changer malfunction, disc may be caught in machine or changer requires service.
If you have a steady hand... carfully unscrew and open up the unit just far enough so you can either pull, or nudge the CD tray enough for the CD to be seated in the tray properly...
Good luck...
Nov 20, 2012 | Televison & Video
Magazine won't eject?
On my Mitsubishi 6-cd changer it won't load cd goes in and out 3times but spots it out
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
The 6-disk cd changer in my '04 silverado z71 will not load or eject cds. When I push load the cd emblem on the screen goes away for a while. When I push eject it tells me there are no disks, but I have...
the laser system this damaged you have two options to repair the laser or to change to The 6-disk CD to changer but cheap is to change to the 6-disk CD to changer
Jul 05, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Cd changer won't play, load, or eject
Had the same problem on our 03 yukon (not the changer but the main head unit) - have a 3rd party waranty and they replaced it. You can get the part for less than 300$ and it's easy to install.
Jul 04, 2009 | 2007 GMC Yukon XL Denali
Peugeot 307
having same problem. faulty after disconection of battery
Jun 03, 2009 | Blaupunkt Car Audio & Video
2005 GMC Yukon Denali Bose CD inop
04 yukon denali bose system c.d. are stuck nhon will play gives me code E.Q.-4
May 19, 2009 | Car Audio & Video
My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Jun 27, 2008 | Car Audio & Video
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
