To set up your home theater system with the equipment you mentioned, follow these steps:
Connect the Onkyo receiver to the NEC TV using an HDMI cable. Make sure the HDMI input on the TV is set to the correct input for the Onkyo receiver.
Connect the Panasonic DVD player to the Onkyo receiver using an HDMI cable.
Connect the Firestick Lite to the Onkyo receiver using an HDMI cable.
Connect the Panasonic speakers to the Onkyo receiver using speaker wires. Make sure you connect the speakers to the correct speaker terminals on the receiver, which are usually labeled with the speaker's position (e.g. front left, front right, center, surround left, surround right).
Configure the Onkyo receiver to use the correct input for each device. For example, set the input to "DVD" when you want to watch a movie on the Panasonic DVD player, or set the input to "Firestick" when you want to watch content on the Firestick Lite.
Configure the audio settings on the Onkyo receiver to use the correct audio format for your content. For example, if you are watching a movie with Dolby Digital surround sound, make sure the receiver is set to decode Dolby Digital audio.
Adjust the volume and other audio settings on the Onkyo receiver as needed to optimize the sound quality.
Once you have completed these steps, you should be able to enjoy surround sound audio from your Panasonic speakers through the Onkyo receiver.
Assuming the DVD player has an HDMI port, run an HDMI cable from the DVD player to an available HDMI port on the TV. Let's say you have your TV service going to HDMI #1 on the TV, you can run the DVD to HDMI #2. When you want to watch a DVD, you must select the input/source on the TV remote to change it to HDMI 2(or whichever port you used). When ready to watch TV again, use the same button to change back to HDMI 1 (or whichever HDMI port you used for TV service). If you do not have an HDMI port on the DVD player, then you must use whatever type of connection it has and connect to the corresponding port(s) on your tv, Then follow same directions as above regarding choosing the input/source on the TV remote.
Use another input for the video and audio like the yellow input and the red and white audio on the TV (the 23 are grouped together). If the Player doesn't work then the player is defective. Picture of cable below
If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...Setting Up your DVD Player - Connecting with an HDMI Cable
? 2:57
https://www.youtube.com/watch?v=8pARHjY8xoo
Jul 5, 2011 - Uploaded by All About Home Electronics.com
Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
You do not plug Chromecast into your laptop HDMI port, it is a video source, so you need to plug it into an HDMI port on your TV. Your TV is an HDMI target, the view side.
If you can run Chrome browser on your laptop, you can cast from your laptop to your Chromecast device and watch that frame on your TV.
Does that make sense? Have a look at the link below for more info. Plug In Chromecast
I check GPX D1816 - DVD player Specifications but didn't see an Ethernet or wireless connection(so you can stream down video). If it did then you can use RCA/HDMI cable to connect this to a TV.
Does Netflix support captions on their content? Typically the device settings (the TV in this case) only displays captions if they are provided by the source (ie cable tv provider, a bluray disk, satellite content, etc). If Netflix does not stream their movies with captions in the content, then your tv (or device) will not be able to display it.
A portable drive won't get you internet, but if the drive contains any media files or movies you may be able to watch those if they are compatible. You plug the drive into the USB socket on the set. If you want internet buy a google chromecast (or similar device). The chromecast plugs into an hdmi socket on the tv and you set it up to your wifi Google Chromecast review can you make your dumb TV smart one for just 35
