When i touch the screen the screen is not responding, what should i do? i started several times but stil the same. thanks
SOURCE: toshiba estudio 161 copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
SOURCE: Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
SOURCE: 3 flashing lights + "call for service" displayed and won't copy
This model was notorious for that code.
It is a Laser Unit failure. Some tech bulletins were issued reguarding installation of grounding straps or replacement of entire Laser Unit.
SOURCE: how to configure toshiba Estudio 232 network
1. You need first of all USB Print&Scan dongle :)
2. On control panel press "user functions"
3. then select admin tab
4.press password and type password (default is 123456)
5. press network and then ipv4
There you need to type in free IP address, subnet mask and gateway.
For more ask your network admin
SOURCE: toshiba estudio 232 screen freez?
Hi how are you this is jack..
Dear you copier screen freez..
you press 0 and 8 key Simantenesly and other and on the copier.
when copier show CHECK TOTAL COUNTER.
WHEN you press 690 and start key. copier show 2 2
then you press ENTER AND when copier show REBORT THE MACHINE THEN OFF THE COPIER.. AND Simple ON.
Please vote me.
Thanks
Best Regards,
