Cars & Trucks Logo
A
Anonymous Posted on Oct 07, 2016
My Peugeot 106 makes short beeping sounds when shutting down. Car stars normally, but again when shutting down beeps four times and stops. What does this mean?
traci
Level 3:
Master:
  • Master 57 Answers
  • Posted on Oct 07, 2016
traci
Master
Level 3:
Master:
Answers
57
Questions
Helped
13268
Points
1473
This might sound crazy but have you got a aftermarket sony stereo fitted because my dads stereo makes this anoying beeping sound everytime he turns the ignition off, if so its nothing to worry about :)
1helpful
When i drive my car there is a constant beeping noise but it stops beeping when i come to a complete stop. please help!! Peugeot 206cc 2003
It sounds like it could be a seat belt sensor. These only work when the car is moving. Do you have anything on the passenger seat that could make the car think there is a passenger there?
Try fastening all the seatbelts and see if the beeping continues. If there is no beeping, try unfastening the seatbelts one by one & see if you can find which one is causing the problem.
if it turns out it is a seatbelt sensor, you could drive with that belt fastened until you can get the sensor replaced.
Stop 2006 Ford crown vic fro m beeping
Austin Parker... hello,
When car electronics DECDE to act strangely... it is ALWAYS a good time to check for BATTERY TERMINAL corrosion...
(If you are not comfortable playing with highly corrosive materials... IT'S SERVICE STATION TIME.
So...
You have removed the key... The car is fully in PARK...
BRAKES applied... Lights all turned off... (no lights on dash?).
Repeat your last exit cycle...
Get back in start the car... Make sure everything functions as normal Set your brake... Park, off the lights (everything)...
Put it in gear...
Still beeping... (write down your radio settings)
Time to do a Bill Gates... (hard power cycle)
Disconnect your negative battery lead
and take a 10 minute break...
Reconnect battery... start car & park it again... OK?
ELSE...
If it resumes beeping it will be time to beg, borrow or buy that OBD Reader you always wanted any-way!
HOPE this helps
More Information for DORMAN 85641
Equinox beeps when parked
A simpler solution: Turn off your AC. It has a sensor that beeps when it's over-heated. If you have a trip that will take a couple of hours or more, top off your coolant and turn your AC down to its lowest fan and temp level. You're welcome.
Makes beeping sound
It means that radio wasn't coded to you car - you'll have to visit a dealer or someone with peugeot planet (or diagbox) interface, and have your car's VIN coded into your radio.
Audible beeping sound when starting car and when driving
parking sensor beep?
if yes then if one of the sensor fails then all system goes off and keeps buzzing
Recently, my car started beeping. The sound comes from the dashboard (somewhere) and there are no indicator lights on anywhere (Check engine, battery, oil, etc). Upon starting the car, a long beep begins...
It could be a fault code being reported
you haven't mentioned a make or model
take it to an accredited service center that has experience on the make and discuss the problem with them
2answers
Peugeot 106 1.5 diesel, slow with no power
no its not right,either change the fuel filter and air filter .if still no joy then get someone to check the injector pump timing because it sounds like someone has changed the timing belt and not done it right..the cam and pump are locked up with a 8mm bolt through the gearwheel into a indent hole behind and ???sounds like weekend mechanic job ,couldnt or didnt know how to sort ot or what they done ??so flogged it quick
3 beeps after shut off.
Sounds like a shorted key fob or intermittent BCM problem.
4helpful
2answers
1996 Ford Taurus Making a beeping sound
was the vehicle ever in an accident? Does the airbag light come on when starting? If the lamp is burned out it will send an audible beep to warn
3answers
Beeping noise - 2005 Mustang
You know, I have a 2005 Mustang GT that honks randomly. MAKE SURE you troubleshoot it now. I waited and now my alternator is fried. About 95% of voltage disturbances can be contributed to the alternator, and from what I understand the alternators on our cars are notorious for crapping out. -Amanda
Top Peugeot Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Arnie Burke
Arnie Burke
Are you a Peugeot Expert? Answer questions, earn points and help others
