Dishwashers Logo
A
Amanda Sonnekus Posted on Sep 16, 2016
Why does the manual say that I have to fill the salt dispenser with water for the first time,do I fill it up with water and when do I fill it with salt Thanks Amanda
Have a hotpoint aquarius dishwasher Won't work powers up Red light comes on with salt 2 nd red light come on showing X What is the X? Please
Here's what you can do to address this issue:
  1. Check the Salt Level: Ensure that the salt reservoir is filled with dishwasher salt. The dishwasher needs salt to soften the water and improve the cleaning performance. If the salt level is low or empty, refill the reservoir with dishwasher salt.
  2. Check the Salt Dispenser Cap: Make sure that the salt dispenser cap is securely closed. If it's not closed properly, it can cause the "X" symbol to appear on the display.
  3. Reset the Dishwasher: Try resetting the dishwasher by turning it off at the mains power supply for a few minutes, then turning it back on. This can sometimes clear error codes and restore normal operation.
  4. Check for Blockages: Ensure that the salt dispenser and its inlet are free from any blockages or obstructions that could prevent salt from dissolving properly.
  5. Consult the Manual: If the issue persists, refer to the dishwasher's user manual for troubleshooting steps specific to your model. The manual may provide additional information about error codes and how to resolve them.
If none of these steps resolve the issue and the "X" symbol continues to appear on the display, it may indicate a more significant problem with the dishwasher that requires professional diagnosis and repair. In such cases, contacting Hotpoint customer service or a qualified appliance technician for assistance is recommended.
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 • Dishwashers
Water in Salt dispenser
salt dispenser?
Apr 29, 2013 • LG Dryers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 • Dishwashers
What do these lights mean there not going off
6helpful
Bosch sgs45c02 salt container ful of water
the salt dispenser is always full of water, this is normal and you have no need to drain it. Just ensure you fill the dispenser with salt when the "Low Salt Light" is illuminated
1helpful
2answers
The tank where the salt goes should that be filled with water, never used a dishwasher before
Yes it should. Mine is always full of water when I fill it with salt. If there is no water how can the salt dissolve?
Dishwasher and salt
run a few times with nothing in the machine on full washes it may be that the salt you are using is not suitable for that machine also check that you have the machine plumbed into the hot water outlet.
Thanks J
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
