Follow the upper radiator hose to just under the coil pack. Remove the 2 13mm bolts. Assembly should separate easily. Clean area. Remember top of thermosta faces to you!
the thermostat is place between the engine block and the radiator either in a housing on the block or in the top radiator hose , follow this u-tube link for step by step guide , nice and easy Thermostat replacement on 2002 Town and Country
drain coolant system half way until coolant below thermostat.to locate thermostat follow upper radiator hose to engine.just remove both thermostat housing two bolts then clean all traces of old gasket material. be sure to have new thermostat gasket and gasket sealer on hand.make sure both thermostat housing and engine block clean dont have any traces of old gasket material if so you will have coolant leak.but besure to put gasket sealer both sides thermostat gasket just need thin layer RTV silicone.you can buy can of gasket remove to help remove old gasket material. try not to damage thermostat housing surface or engine surface with scraper deep scratches cuts in either surfaces will cause coolant leak be careful.
The location of the thermostat for most vehicle.
Stand in front of the car with the hood open, you'll see a black hose hooked to the upper side of the radiator.( about 2 inch in diameter, newer vehicles about 1 and 1/2 inch, and newer small cars about 1 and 1/4 inch. ) Follow the hose to the other end, it connects to the thermostat housing. The thermostat is inside of the housing.( the hose usually goes to the air intake manifold, but some housings are on the side or back of the engine. )
Follow the top radiator hose back to where it connect to the engine. There is a housing there that the hose connects to. There is two bolts you have to remove to get the housing off and the thermostat is underneath the housing. 4 thumbs up is appreciated if this helps.
Trace the water hose back towards the engine. When it stops you have located the thermostat. Remove and place in some boiling eater. If it opens the thermostat is not defective.
