Panasonic KX TGA680B DECT Accessory Handset Logo
Herb Matthews Posted on Apr 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do I see Base no power on display which also shows Charging?
Jay Plesset
Level 3:
  • Panasonic Master 2,942 Answers
  • Posted on Apr 12, 2016
Jay Plesset
Panasonic Master
Level 3:
Answers
2942
Questions
Helped
668611
Points
9879
Your phone is trying to connect via radio to a "base station". If you don't have one, your handset cannot work.
If you have a base station, your handset may need to be "registered" to it.
The handset shows "Out of
defective ,,,,ignore display,,it still works
75helpful
5answers
Lg rd 3500 show charging on display but power not save , what i do?
lg rd 3500 show charging on display but not charging.....plz solution
1helpful
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
4helpful
Phones are powered but do not connect to base so can't receive or make calls. Is there a way to reset?
The manual, which can be found at: http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf, reads:
4. Place the handset in the base cradle. The charge/in use indicator turns on,
verifying the battery is charging. The unit will take 20 seconds to register
and verify its security code. READY shows in the display.
NOTE: In case of a power failure, the handsets may display
UNAVAILABLE when the TALK/CALL BACK button is pressed.
You must then place all handsets on the main base cradle
for 20 seconds to re-register.
That should reset your handsets. Hope this helps :) Thank you very much.
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
1helpful
Tried to reregistering
Hi
Please try the following procedure:
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
1helpful
Charging problem
if charger is problem it happen like this.
change your charger!
14helpful
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
