I am getting a TOC error on the left drive. I cleaned the laser, still get the error. I replaced the laser with a new one that I bought and I still get TOC error. Disc spins for a few second and stops 4-5 times before disc error appears. Thanks
Also if you have not installed a new laser before , all new lasers come with a solder bridge that needs to be removed before you can use it.
Table of Contents errors can be the result of bad compact disk, bad laser or the head cannot get into position to read the TOC, Make sure that the new laser is aligned correctly and that the head has no obstructions at either end of the rails. Last but not least you may want to make sure the laser is working and you can check that by using a camera like the one on your cell phone, With the cover off, insert a cd in the drive and have your camera pointed at the area of the laser. You should see the laser light on your camera.
