The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
You'll need a digital cable box for that, I'm afraid. The analog tuner in the set isn't compatible with the digital cable signal. The cable company in my city just dropped their analog service. Now you either need a digital converter box, or a "cable box lite" called a digital transport adapter. For digital off-the-air broadcasting you need a digital tuner and probably an amplified or outdoor antenna. The analog TV is rapidly becoming pretty useless except as a display device as analog channels disappear.
You need to connect your source to your receiver with a Digital coax cable or a Optical cable to get true surround sound. Analog will only give you simulated surrond sound.
Try an antenna if you want to get analog over the air. I have a feeling that with the way the standards are changing, you will only be able to get digital channels. After February, the analog channels won't be around.
If you are using cable tv you need an HDTV box to get high def.
