SOURCE: setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
SOURCE: answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
SOURCE: set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
SOURCE: How do you set the number of rings before the answering machine picks up?
Here's a link to the manual on AT&T's site:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=284
SOURCE: set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring
service, then set the printer to receive faxes manually (Auto Answer Off). This
setting lets you receive both voice calls and fax calls, but works best if you
use voice mail more often. You need to turn off voice mail whenever you are
expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
