The above Interlock kits are vastly overpriced. As long as the upper right hand breaker is available to use as your generator link, the kit should be good to go. Save the extra $100.
These units are equipped with a low/no oil shutdown. When you hold the switch over to start it, it overrides the shutdown interlock until the unit builds oil pressure in the engine. When you release the switch to the run position the interlock is engaged. Ensure there is sufficient oil in the crankcase, check the wiring from the oil pressure switch to the ignition cutout-(it may have been pulled off or damaged). If that checks out, then either jump across the 2 wires at the oil sending unit or disconnect the harness from the sending unit to test to see if the sending unit is bad. Try both unless you know the switch is normally open or normally closed. Replace the sending unit if needed.
