20 Most Recent
I Power In Box Honda Eu1000i Power Generator Questions & Answers
The generator will not hold the load.
Confirm that the ECO-Throttle Switch is in the off position. When in the ECO mode the unit goes into an idle condition and when detecting a load will spin up to operate the load.
In the off position the unit will remain in the ready for load speed taking the initial load with less hesitation.
If this does not solve the problem it is likely the carburetor has some old fuel residue. This residue restricts the fuel flowing through the carburetor. Suggest using a fuel additive carburetor cleaner added to fresh fuel and allow the unit to run under load for an extended period. These gas treatment products are readily available at any auto parts store.
These carburetors have no adjustment for fuel mix and after trying fresh fuel and cleaning the fuel system with additive the only remaining choice would be cleaning or replacing the carburetor.
Honda eu1000 lacking correct ac power output
hi wizman sorry not answered your reply to me about a week ago ,just too lazy and lost a lot of interest in this site since it was changed ,trying to find the new questions as they come in ,and the odd 4 dollar ones which goes towards my phone bill and this new lay out and questions filling my inbox ,anyway now to answer this one i suppose and i think here i would need more info as to how it was before it was rebuilt .But i would have a play and strip and clean the carb first .right now to see what else i have been sent as star trek is on TV in 20 mins .
Honda 10001 does not run with choke open runs
Did you check the air filter air restriction would make it do that . Its eighter that or you need to take the carburator off get a can of carb cleaner with the plastic nozzle take it apart and spray out all of the venturies and the main jet clean every thing good . Know this all carburators work exactly the same they may look a little differant but once there off idle its an automatic system the adjustments don't matter that much and the passages are small all it takes is a monor restriction in one of them to give you a problem . The good news is you don't have to buy any parts if its not the air filter clean it and it will work like new note where the adjustments set by the number of turns out from the stop most you will not be able to change the idle is nornaly set 1 and a 1/4 to 1 and 3/4 out from the stop or complete shout off and check to neddle valve to make sure its sealing good its the one that rides on the top of the float and shuts the fuel off to the float bowl from the tank when the bowl is full if this seal leaks it will flood the engine with fuel this could also be the problem . In ganeral look for things that look dirtyif its clean it will work
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
