1998 Ford Windstar Logo
J
Justin White Posted on Jan 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
98 windstar keeps dying
The altenator was checked to be good and ive wiggled the fusible link off the fuse panel under the hood. im checking the relays now. any advice
Claude Kayser
Level 3:
Top Expert:
  • Ford Master 9,098 Answers
  • Posted on Jan 23, 2016
Claude Kayser
Ford Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067710
Points
28436
Ford Windstar Starting/Stalling Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Then yesterday the car just died while driving and had to be towed back to ... On pre-98 Windstar, it might be called CCRM (Constant Control ... Ford Windstar Alternator and Battery Problems
Oct 24, 2006
Ford Windstar Electrical Problems
Apr 14, 2006
More results from forums.edmunds.com
my battery on my 98 ford windstar keeps dying? ' Yahoo ...
https://answers.yahoo.com/question/index?qid...
Mar 20, 2007 - while driving the battery will short out and sometimes turn right back on, causing the van to die. 2000 Ford Windstar battery keeps dying after changing alternator ...
Jun 23, 2010
Alternator keeps dying in 1995 ford windstar, already been through ...
Oct 7, 2007
Battery keeps draining in 99 Ford Windstar Van?
Sep 5, 2007
My 1998 Ford Windstar's battery keeps dying, why? Also the ...
Dec 16, 2006
More results from answers.yahoo.com
98 windstar 3.8 problems - CarGurus
My 1996 s10 blazer with a 4.3L was idleing warming up and id died and hasnt st arted since. ive got no fuel prtessure no spark no voltage through the ECM fuse and no cluster lights. Help
You talking ecm bat fuse 20 amp? Voltage to that fuse is hot all the time. It comes from fusible link. Make sure battery has a full charge and connections all good. Then check fusible links, one way to check fusible links, use a test light and check voltage on both sides. I usually follow battery + circuits to find fusible links.
1helpful
2answers
98 ford ranger 4cyl 5 speed. When u turn the key to on position I get no warning lights on dash except battery light and seatbelt light. Nothing else.truck wont start. Dont even click.
Check the batter voltage first. If not that check fuse panel under hood for a 100 amp fuse check to see if the fuse is bad or if it has power. Also check fuseable link wire at starter to see if wire is still good. If it is bad, internal short possible on starter, take out and test it. Replace fusible link.
What number fuse is the ALTERNATOR IN FORD WINDSTER 2000
a lot of times its a fusible link not a fuse. but sometimes its the main 100 amp fuse on fuse panel under hood.
How to tell if one or more of your fusible links are bad on a nissan murano
to check to see if your fusable links are shot, grab one by the cylinder, then gently tug at each wire at each end, if it comes right out or elongates, its toast, replace.
I have a 1985 Honda prelude carberated an the battery light won't go out I bought a brand new altenator an battery but when I rev it past 3000rpm it goes out an it seems to be running off the battery I can...
The alternator is not charging, even if it's new, you probably have a fuse that is blown. Look in the fuse panel under the hood where the big fusible link style fuses are held. I think you'll find that one of the larger fuses in this panel is bad. They are hard to see sometimes, a multimeter may be needed to check them.
2answers
I have a 2000 ford windstar battery light comes on bought a new alternator battery was told is good too what else could be wrong?
check altenator connections,is belt slipping? check your fuses also the ones under hood in black box
2helpful
Not charging replaced altenator still not charging
Check the wire from the altenator to the battery. The large wire on the back of your altenator may have a fusible link in it. Check this wire with a multimeter set on continuity or resistance. If the ohms read low the wire is fine, if the ohms read high or infinite the wire/fuse link may be bad. There is also a main fuse in the box under hood to check>
98 ford windstar no dash and tail lights
you have to check all fuses with a test light both fuse boxes under hood and under dash... if good next to look for is the light switch itself... has any radio work been done to the lately... if so alot of times hooked up wrong will blow park fuse as one of the wires to radio is the park voltage to tell radio to dim down some
1helpful
2answers
No electrical power 1994 S10 Pickup V-6 4.3 L
your fuse box is inside , lower left kick panel , check all fuses in there , then also in the engine compartment on the firewall around the middle is a junction block with like 2 fusible links , they need to be tested , and also 1 fusible link right off the positive side of the battery , test it also , if you don't have a test light for testing , you can kinda wiggle the fusible links and feel if they are limp and stretchy , that's not a good sign , you can buy replacement fusible links or fusible link wire from local parts store , depending on how much sparking happened you may have blown the fusible links . if you don't have a test light , pick one up at the parts house and learn to use it , it will be invaluable when it comes to testing this kinda of failure . cheers .
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
