Hello jpdarrish,
“” Having similar problem as many with machine not spinning and stalling at the first spin cycle and never completing. I opened the lid during the cycle and see the tumplers will spin ok but the tub will not spin and cannot move in either direction by hand.”” Was this the original issue before you removed the clutch? Were you taking dc or UC errors to the display?
“”As a note, the tub will turn freely by hand while the clutch is disengaged. As soon as it's seated, it's impossible to turn the tub by hand.”” By disengaged do you mean that the clutch pulley was removed from the machine and the wash basket rotates CCW freely?
With the Clutch pulley installed properly the wash basket will only rotate CCW it will no rotate CW that is normal operation. You should beable to rotate the wash basket CCW with one finger and very little resistance with the clutch installed.
""I did remove the clutch assembly. The sping mechanism looks good. I used WD-40 and some bearing lube on the needle bearings. But the bearings will only turn in one direction. Is that normal? Anyway, I reassembled (took a bit of work to get it completely seated) and tried but still having same issue.""
Yes this a Drawn Cup Roller Clutch designed to rotate one way only clockwise for our FAV6800A/FAV9800A machines.
My description of how I believe the Roller clutch bearing engages the spinner shaft to spin the clutch basket.
This write up is my understanding of how this clutch system works in the FAV6800AW/FAV9800AW. I could be wrong and would invite any comments from the forum to help me better understand how the clutch works in wash and spin cycle;
The clutch in the FAV6800AW/FAV9800AW incorporates a Drawn Cup Roller clutch bearing. This roller clutch bearing will allow one-way rotation freely in clockwise rotation. The FAV6800AW/FAV9800AW washer uses a reversing motor which has power supplied by the motor controller. In wash cycle the motor controller powers the motor to produce clockwise rotation which turns the clutch pulley CW. The Roller Clutch Bearing spins freely in the CW direction so only the agitator shaft will rotate driving the transmission to rotate the tumblers. In spin cycle the motor controller powers the motor CCW. This rotates the clutch pulley CCW and the Roller Clutch Bearing locks up and drives the spinner shaft CCW. At the start of a spin cycle the tumblers will rotate ¼ to ½ turn of rotation and no more as the clutch spring is wound to tension. Once the spring is wound to tension the spinner shaft begins rotating the spinner plate which rotates the transmission and wash basket CCW. Because the transmission is spinning at the same rate as the wash basket the tumblers do not rotate. This will happen if the clutch spring is broken and in spin cycle the wash basket will spin very slowly with no clothes in the wash basket and the tumblers will rotate. You will need to replace the clutch.
Dose you clutch look like the one on the left or right? My is on the right and my machine is a series 16 1st digits of my s/n are 16.
If your Roller Clutch bearings rotate freely in CW direction and you installed the clutch pulley correctly you should beable to rotate the washbasket CCW with the lid open with one finger. If it dosent we have some binding issues with the clutch install. This is from a post of a forum member I helped. He has a good install fitment process. This is a challange but I can no do to it in less then 5 min. after a dozen or so clutch removal and installs of my machine.
""The Service manual download was very helpful because it has a few pictures to show the 1/16"-1/8" gap from the shaft to the clutch face. What this really is telling you is that "if" you get all the three parts (clutch plate- bearing sleeve and cream colored plastic piece with 2 raised projections) to the clutch assembly back in correctly, you will end up with the 1/16"-1/8" gap. I also did my repair by tilting the machine back and working on it in place. Test the fit of each of the 3 pieces seperately so you will have a better idea what you are trying to fit. The cream colored plastic piece with 2 raised projections "seats" into the bottom of the tub. The bearing also seats onto the shaft in the notches. The clutch simply fits on the square shaft. The trick is getting the 3 piece assembly on with every piece seated correctly. By no means impossible, but working in limited space it was the most difficult part to do. Something that I thought of (after the repair) was to actually cut out the sheet metal directly below the clutch. This would allow easy access for the reassembly.’”
Again I believe your original clutch uses the upper bearing piece, as pipespike states you have to get the fitment of the upper bearing assembly the bearing sleeve I call it the coupler and the clutch seated properly to get that 1/16"-1/8" gap shown in the Service manual page 47.
Try a reinstall of the clutch after reviewing the above comments. After the clutch reinstall first try to rotate the wash basket CCW with one finger it should offer very little resistance and not rotate in a CW direction.
Post back for any additional help. Rich
