SOURCE: Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
SOURCE: I need the manual for the Hobart 20 Quart Mixer
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
SOURCE: how to change oil in 20 quart hobart mixer and the
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
SOURCE: hobart mixer making grinding noise
the noise is not a good sign. would rec. taking apart trans. and investigate gears,shafts, before futher damage takes place
SOURCE: LEGACY 12 QUART AND 20 QUART COMPATIBILITY????? I
I couldn't find anything on the net to indicate the 12 qt and 20 qt would be interchangeable. You best bet would be to contact the manufacturer through the information in your manual.
The units may look the same in the parts book, but they simply, because of volume, couldn't be the same size.
Good luck, perhaps Hobart has a solution.
