20 Most Recent Hobart HL200C Mixer Questions & Answers
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Hobart HL200C... | Answered on May 15, 2018
hello! the speed select switch is defective...It is located behind the timer control board...Part # is...00-874831
Guru.............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Hobart HL200C... | Answered on Apr 01, 2011
Here is the complete manual of parts with exploded views and part numbers:
http://www.wasserstrom.com/wcsstore/ExtendedSitesCatalogAssetStore/Attachment/item%20680610.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Hobart HL200C... | Answered on Dec 05, 2010
It is difficult to determine the exact cause of the problem but it most certainly lies in the speed selector switch itself. The switch is a rotary mechanical switch which can only take so much wear and tear.
You can view your mixer online at:
http://www.hobartcorp.com/products/food-prep/mixers/legacy-countertop-mixer/
There are contact numbers and a dealer directory on the web page to direct you to your nearest stockist of Hobart parts and accessories.
Best wishes,
Graemevm
Hobart HL200C... | Answered on Mar 16, 2010
Motor start capacitor failed or start run switch mounted at back of motor housing damaged
Hobart HL200C... | Answered on Nov 13, 2009
For $9.95....I'll tell you
Hobart HL200C... | Answered on Dec 11, 2008
https://www.manualslib.com/manual/1026745/Hobart-Hl200.html
Looks to be a drift pin missing. See parts diagrams in above manual.
Hobart Food... | Answered on Jan 10, 2020
Contact Hobart directly to inquire.
Hobart Food... | Answered on Oct 31, 2019
Try this.
Take two flat blade screwdrivers and slip the blades between the planetary and the mixer body (on opposite sides) pry it off.
This has worked for me.
Hobart Food... | Answered on Oct 26, 2019
Hobart HL200C Mixer Logo
9 questions posted
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Hobart Food Mixers
  • Hobart Food Mixers
Most Popular Question
need wiring schematic hobart 200t
  • Food Mixers
