SOURCE: Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
SOURCE: MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
SOURCE: how can i deactivate the protect that blinks in my
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
SOURCE: My Kenwood car stereo keep falshing the word "Protect" how to fix
in front of your #1 preset button there is a reset button push it with a pin. if you made a pass # put it in if not page 12 show you how to make one if you want. reseting it should make it work if it dont you have a short somewhere start from scratch buy taking it out. I suggest you dont make a password till the short is gone. Mine did the same thing but because i was pulling to much power on starting my car with my amps.
SOURCE: My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
