Any item not changed in the harness. like the light socket itself could be corroded, faulty, loose, or misaligned contact. same with any other electric component not changed by the harness or switch. If this is a digital unit then a board could be involved as well same problems with broken solder joint added.
You have a loose part. Because they DO switch on briefly, it's clear that the electrical connection is going through and you do not have a non-working piece. Somewhere in the wiring, something is loose. You will likely have to have it repaired by the company or get it replaced.
