Amazon Kindle 3G Logo
Very slow responding to requests. Why does it sometimes indicate "The selected application could not be started. Please try again"?
How do I make my Nextbook tablet stop randomly closing apps while in use?
It's not a good make and if you reset and it didn't fix, then it is a hardware issue and isn't going to improve. Apple iPad is the brand leader for a reason.
16 Gb capacity is very low, my iPhone 7 has 128 Gb. Try removing some apps. Ideally you don't want to have more than 60% full.
How can I improve the touch of my screen it takes forever to respond
Hi it's possible youre tablet has a faulty glass screen digitizer ,cheers
2answers
Apps not responding an running very slow
Everything is suddenly slow or is not responding. - Windows 8 Forums
www.eightforums.com > ... > Performance & Maintenance
Jun 24, 2014 - 10 posts - ‎2 authors
... year old and it started to load everything really slowly or is not responding for ... of memory to run Windows 8 efficiently so that isn't the problem. ... (It's not always showing, that the application is not responding, when it froze).
Solved: system is extremely slow and everything is "not responding ...
forums.techguy.org > Forums > Operating Systems > Windows 7
Sep 13, 2013 - Solved: system is extremely slow and everything is "not responding" ... Only after several minutes do the programs become responsive again, but once I try ... If using Vista or Win 7 - right click the icon - run as Administrator
iMac very slow, apps not responding, wheel turning ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 28, 2012 - iMac very slow, apps not responding, wheel turning ... (Expect it to take longer to start this way because it runs a directory check first.). Mac runs super slow and apps not responding
Apr 23, 2015
running very slow and apps not responding
Sep 20, 2013
Macbook running slow and all applications stop responding - Apple ...
Jul 29, 2012
Running slow, Not responding
Oct 10, 2011
More results from discussions.apple.com
I have responded to all of your requests to no avail. I can only retype this simple request so many times. once again my reset button on the outside of my d2-721 tablet will not respond, for a hard re
If the button does not respond it might be broken. If you have a slip case on your tablet it might be stopping you from fully depressing the button.
Download google play
1chek memory if you have inoughmemory spece 2check for firmware update.if all its okey and you stil have problem with it.folow me...with pc.go to google download kies for Samsung 2install it.3check debuginging inthe phone setings 4connect your phone with USB cable now you're good toGO if your phone its OEM.(original manufacture)you'll see some thing like a box down the screen
My hp tx2 tablet pc turns into safe mode and running so slow
Follow these guidelines:
1. Turn a power-off computer on or reboot a running computer.
2. Quick press the F8 key on keyboard before Windows starts, after hearing a beep sound you will be taken to Windows Advanced Options Menu instead of the normal loading page. If it doesn't work on the first try, just reboot and try again. And Select normal loading option.
Fix windows internal errors and corrupt registry to avoid such types of errors in future. I would suggest to use system utility tool Reginout.
2answers
My sony viao pcgn505a is very slow when i open it. It has also a samok virus and very slow internet connection. Please help how to reformat it and where to get drivers for it. Thanks.
I would suggest try avoiding formatting. Because if you do that, then the next problem you will face is to find, download and install all the drivers.
If you are using the Genuine Windows operating system, then download 'Microsoft Security Essentials' for free from the Microsoft website. This should take care of your viruses.
Second get the latest Service pack provided by Microsoft and this should update the drivers.
And basic things, like removing unnecessary files, Defrag you hard disk, etc should also add up to the speed.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
