should be 4-5 nuts/bolts.
remove bolts, pull cover off. (pry edge with small screw driver if too tight or tap around sides with rubber mallet to loosen.
pull off all old gasket from cover and top seal area on head.
clean up all parts and wipe dry.
apply the new gasket. see image below.
make sure the 3 rings inside the cover are replaced, then reinstall.
do not over tighten.
torque spec
1.8L engine - 43-78 in-lbs 1.9L engine - 50-100 in-lbs 2.0L SPI engine - 71-97 in-lbs 2.0 Zetec engine - 54-70 in-lbs to convert from inch to foot pounds just divide by 12
