20 Most Recent Porter Cable C2002 150 Psi 6 Gal Compressor Questions & Answers
2answers
Can i use existing drain plug for porter-cable pancake air compressor?
Yes use pipe thread seal. The center is turned to open and close no need to remove plug. If is frozen replace.
3/17/2021 9:57:17 PM • Porter Cable... • Answered on Mar 17, 2021
2answers
My four-year old PC pancake compressor starts fine
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
1/2/2019 1:23:17 PM • Porter Cable... • Answered on Jan 02, 2019
My c2006 compressor filled with
they have this common problem ck out here.. https://www.youtube.com/watch?v=s5eWvRzEmuQ hope this helps.
1/12/2018 3:37:40 PM • Porter Cable... • Answered on Jan 12, 2018
I bought a brand new Porter Cable pancake
Have you turned the knob on compressor regulator clockwise.?
12/1/2017 2:39:52 AM • Porter Cable... • Answered on Dec 01, 2017
2answers
Hi, I have a porter
indicates a failing start/run capacitor for the motor as most small compressor do not have an un-loader for the start and the motor is strong enough to start with a reduced load when the controller switches the power back on
11/21/2017 5:25:18 PM • Porter Cable... • Answered on Nov 21, 2017
Unlocated substantial air leak. It is not a hole
the reed valves/ poppet valves have failed in the cylinder head /s allowing the air to continually pass from in and out with each stroke
11/6/2017 10:43:37 AM • Porter Cable... • Answered on Nov 06, 2017
How to test electric switch on porter cable air compressor
What you need is something called a volt-ohm meter. Obtain one and use it to test your switch and wiring.
10/24/2017 7:06:05 PM • Porter Cable... • Answered on Oct 24, 2017
Will not build air enough to cut off from
Check for internal leaks ... Some time it is simple O0ring replacement. Better to replace a fitting completely with more advance options. Or even better toinstall Digital Controller. Check this site: www.CompressorController.com
10/19/2017 11:34:29 PM • Porter Cable... • Answered on Oct 19, 2017
Porter cable c2002 does not shut off automatically
Pressure switch problem ! Replace all for Digital Controller. Check this site for solution: www.CompressorController.com
10/19/2017 11:30:31 PM • Porter Cable... • Answered on Oct 19, 2017
Tank will not cut off by its self
Do you meant - your air pressure switch ? Advise - install an digital Controller and all problems with your compressor goes away. Check for Compressor Controller
10/19/2017 11:26:39 PM • Porter Cable... • Answered on Oct 19, 2017
How to replace porter cable air compressor drain valve
Install an Controller with automatic Digital control of drainage time - will save you money. Check for Compressor Conroller
10/19/2017 11:24:55 PM • Porter Cable... • Answered on Oct 19, 2017
Compressor wont shut off only gets to about 100psi I can also hear a air leak under the cover but if I manually turnit off the air leak stops and it hold air do you think its the tube seal.
There is a cheap connector where a pipe entering tank - Oring usually failure in first 3month. Advise to replace for better fitting.
10/19/2017 11:23:40 PM • Porter Cable... • Answered on Oct 19, 2017
Intermittent recovery, cycles several times before the motor will run, I am afraid the motor will burn up
Did you check for proper oil level in the compressor? When unit is running use ammeter to confirm power draw to make sure that it is within specs.
5/24/2016 3:54:48 PM • Porter Cable... • Answered on May 24, 2016
2answers
Bleeds off air as it builds up pressure
This compressor has a bleed valve under the tank. It is used to drain pressure. It may be cracked open.
4/21/2016 2:48:08 AM • Porter Cable... • Answered on Apr 21, 2016
Why does the motor run but no air pressure develops?
Could be the belt is off or the pistons are not reciprocating
1/5/2016 11:11:40 AM • Porter Cable... • Answered on Jan 05, 2016
3answers
I have a C2006 Type
first you have a reciprocating pump and the hissing you ear probably comes from the unloading valve on the pressure switch(it will look like a bike tire valve)if there is air coming out the valve when the compressor is off it probably means you have a bad check valve.This valve is use to unload the pressure inside the pump for an easy start .a motor always drive more amps on start up if you cant unload this pressure you will trip the overload(you probably have a reset button on your motor)check the specs on your pressure relief valve ,its a small pump maybe its just adjusted to high.in this case your pressure relief valve will open .If the pressure is fine and there is air coming out the relief valve then you have to replace it!to adjust your pressure turn the screw on your pressure switch clockwise to increase and counterclockwise to decrease .usually you have a 30 psi between cut-in and cut-off called the pressure differential.It can be adjusted on some pressure switch.be sure you put some teflon tape on the treads if you replace something to avoid air leaks.hopes this help!
11/7/2015 6:48:31 PM • Porter Cable... • Answered on Nov 07, 2015
Tank holds air but will not shut off at desired pressure
There is a valve on the unit that is connected to the motor, this valve is adjustable. Look for the cover housing where the cord goes into a box that is mounted on the tank.. Some models have a lever that turns the unit on and off there. Take the cover off and see if any parts are loose. If not then there should be a screw that you can adjust.
5/8/2015 5:38:14 PM • Porter Cable... • Answered on May 08, 2015
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
226 questions posted
Top Porter Cable Air Tools & Compressors Experts
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Porter Cable Air Tools & Compressors
Most Popular Question
  • Air Tools & Compressors
