Stoves 720EF Electric Double Oven Logo
Jonathan Knowles Posted on Jun 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix the time and the timer - Stoves720EF
Timer record does not work
David Payne
Level 3:
Top Expert:
  • Master 14,162 Answers
  • Posted on Jun 24, 2015
David Payne
Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998776
Points
455836
1helpful
Oven timer won't stop buzzing.
Please use tools to unscrew the top portion of the dial from the oven and check if the buzzing stops. If not, then you might need to remove the entire dial/timer from the oven and work with a watch shop to fix the timing function of the removed oven clock. Or you can request the clock specialist makes a home visit in order to fix the oven timer/clock for you instead.
Thank you.
1helpful
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 • Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
How do you set the timer for both upper and lower oven at same ti
most ovens will only let you do a time bake for 1 oven at a time. And a min timer .Same as you can only self clean one at a time. Not knpowing what brand you have , you might want to contact manufacture.
Nov 21, 2009 • Ovens
Dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Preheat worksoven wont bake
1helpful
New world 90TCgyro fan oven timer
From the New World Web site: "How do I set my timer/programmer into manual when it is set in auto? (5 & 6 button versions) On your timer there are two buttons, which read "cook time" and "ready time". If your timer is in automatic, you can return it to manual by pressing these two buttons simultaneously. REMEMBER - if your oven is in automatic it will not work until the time you set it to come on or if you return it to manual." Find more info on the link below: http://www.newworldappliances.co.uk/Common-Questions_p18.aspx
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
