20 Most Recent
Stoves Premier 600EMa Electric Single Oven Questions & Answers
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Oven not getting hot
If the fan is working, then the oven element has failed, you need to fit a new element., it is behind a removable cover at rear of oven compartment.
The grill is nt working
Highly unlikely, either element gone or selector switch faulty, you need to test element with a meter.
Plz leave feedback.
