Kenmore Elite Side By Side Refrigerator - White Logo
Y
Yvette Walker Posted on Jun 15, 2015
The blades in my ice bucket fell apart I have all the parts can you tell me where I can take it to be repaired I live in south Holland Illinois 60473 or send me instructions to put it back together
Model number 79551074001 my e-mail is [email protected] cell number 773 269-7786
The ice level arm catches on the ice bucket when trying to pull out the top freezer tray
Hello Danny;
My name is Peter. I am a retired field service refrigeration technician.
This is just a bad design.
The only thing you can do is raise the lever arm to the shut off position.
Or, you can reform the lever arm so it clears the bucket. In this case you have to manually control the ice maker otherwise the ice bucket will over fill.
Your ice maker will harvest ice cubes 8 to 10 times within a 24 hour period.
Nov 30, 2014 • Freezers
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 • Freezers
1helpful
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 • Freezers
2answers
Ice maker not working properly & Ice cycles in freezer
THIS IS WHY PEOPLE USE THIS SITE.ORDINARY PEOPLE NEED FRIENDS TO HELPOUT....
find an elderly person in your area that needs help, not charity.the feeling is priceless...
Feb 11, 2010 • Freezers
My ice maker stop working
Knowing how an ice maker works can greatly increase your ability to diagnose and repair it. Just like vehicles, ice makers all may look different but they all work on the same princible. A thermostat starts the ball rolling, turning on a motor and a heater to loosen the ice, as the ice dumps a trigger fires up the water valve and refills it. The whole thing comes to a halt and waits till the thermostat gets satisfied once again.
So what can go wrong? The ice maker will give a clue. If their is ice in the ice maker but none in the bucket that is an ice maker failure. If the ice mold is empty and no ice in the bucket then the water valve is bad.
One thing you can do is get a bottle of water and fill the mold. If it kicks out a batch but no more, water valve replacement needed. If it don't then ice maker problem. If you have shelling or fouled cubes, look for dirty coils below the ice box that make for faulty cooling. Ice forms at 32f but ice mold tstats don't kick in the afterburners till 25f. I have some more detailed tips with videos and manuals: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 10, 2010 • Freezers
Sears side by side fridge model# 10652542101. ice won't work but water works fine. have heard that icemaker screen may be the issue, but would like a manual so i can clean or repair it. sears has no...
There is no "screen". Most of these units have dual water valve on rear of unit (two valves on one mounting bracket) located on lower right side of unit. Follow inlet line to where it terminates, you will see water valve. First thing to determine, is the ice maker making ice and not dropping it thru door, or no ice dropping into bucket. Stick finger into I/M and see if you feel ice or if it is empty. If empty (no ice) chance are that I/M is problem, not water valve. Check I/M by pouring water from small glass into I/M,let sit for 2-3 hours and see if it drops ice into bucket, if it does, possible bad water valve, if it doesn't, bad I/M. Those are standard I/M & water valves, available at most applianc parts stores including sears.
Sep 23, 2009 • Freezers
Could you please tell me if replacement doors are available for my LG Bottom Freezer Refrigerator Model No GR-F258JTT . I am living in Perth WA , and if so what would the cost be and who could do the...
look in the yellow pages under large appliance repair. You should be able to find a tech. who can get LG parts and can replace your door or door skin. You will have to get an estimate, or ideally three estimates so you know you are not getting taken to the cleaner. good luck.
Sep 12, 2009 • Freezers
Whirlpool side by side s20erww2v american f/freezer
Is the ice bucket still full? Ice makers have built in mechanism to cut itself off when ice bucket is full.
ICE WITHOUT PLUMBING
it really doesnt matter how full you fill the bucket. round cubes will probably dispense just fine if you have access to that shape ice.
One additional thing, be sure to turn the icemaker off to prevent the fill valve from going bad and to keep it from making a loud buzz about every 10 minutes. thx peyton
Jan 25, 2009 • Freezers
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
