20 Most Recent Kenmore Elite Side By Side Refrigerator - White Questions & Answers
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
Kenmore Elite... | Answered on May 15, 2017
Hold the two buttons down to turn cooling back on, read the manual, should have simple instructions.
Kenmore Elite... | Answered on May 24, 2016
Could be many things, the water valve could be faulty, the icemaker thermostat may have blown, the gears could be stripped.
Kenmore Elite... | Answered on Mar 10, 2016
Removal of Kenmore Elite Fridge Door Water Line eHow This topic is discussed here. Most important, turn off electricity, fridge before you do anything.
Kenmore Elite... | Answered on Jan 22, 2015
Did you flush the system after changing the filter? Air can cause water to leak if it not flushed after each filter change. It takes about 6 to 7 minutes to get all the air flushed out. I hope that helps...
Kenmore Elite... | Answered on Dec 02, 2014
Did you make sure to put the arrow up?
Kenmore Elite... | Answered on Nov 12, 2014
Hello Sherry;
My name is Peter. I am a retired field service refrigeration technician.
1.) If the refrigerator shut down for 20-30 minutes:
Your refrigerator goes into a defrost cycle every 8-10 hours. The refrigerator shuts down for 20-30 minutes. At this time, you have a heater under your freezer cooling coils (Evaporator). The heater turns on and melts the frost off your cooling coils. Then the refrigerator turns back on. This is where you get the term; "Frost Free".
2.) If your refrigerator has shut down and is still shut down:
a.) If it shut down going into defrost - Some refrigerators have mechanical/electrical defrost timers that are easy to access and manually bring it out of defrost. Unfortunately, your refrigerator defrost cycle is built into your main control board.
b.) You main control board is bad. This is a primary electrical part. It is not a uncommon failure. The control board is about $85.00 and easily replaced.
I have faith in you Sherry, lets replace it:
1.) The new control board will come in a silver bag. This is a anti-static bag. Static electricity will not the board out. Ground your self by rubbing your hands on a steel object.
Move the refrigerator out to where you can freely stand behind it. Unplug the refrigerator. There is a metal cover plate about 10" x 12" on the back. Remove the screws and lift up. There are tabs on the bottom of this cover. Now, the control board in front of you is held in place by small white retaining pins. On each side of the pin is a small leg. With one hand squeeze these legs and the other hand pull the control board toward you to free the board from the leg. There are several pins around the board. Now that the board is free, take the new board, systematically going around the board one connector at a time. Remove one connector from the old board and connect it to the new board. Repeat this one connector at a time. Each connector at the top has a clip that you must squeeze to disconnect. Make sure on the new board you hear the connector click. Do not pull on the wires. The connectors are fool proof. The connectors are designed to only fit one connection size. Remount the board on the pins. put back cover on and plug in.
Kenmore Elite... | Answered on Nov 09, 2014
Go online you will find it.
Kenmore Elite... | Answered on Sep 27, 2014
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Kenmore Elite... | Answered on Sep 21, 2014
23 to 29 cubic feet....
what model is it!
Kenmore Elite... | Answered on Apr 10, 2014
Kenmore Elite Side By Side Refrigerator - White Logo
54 questions posted
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
after changing water filter ice maker
  • Freezers
