There is no "screen". Most of these units have dual water valve on rear of unit (two valves on one mounting bracket) located on lower right side of unit. Follow inlet line to where it terminates, you will see water valve. First thing to determine, is the ice maker making ice and not dropping it thru door, or no ice dropping into bucket. Stick finger into I/M and see if you feel ice or if it is empty. If empty (no ice) chance are that I/M is problem, not water valve. Check I/M by pouring water from small glass into I/M,let sit for 2-3 hours and see if it drops ice into bucket, if it does, possible bad water valve, if it doesn't, bad I/M. Those are standard I/M & water valves, available at most applianc parts stores including sears.
