Purchased from Sue Ryder charity shop and was delivered broken down into component parts.
I used to also constantly tinker with assembling furniture and these puzzles until I started making good money. Now my furniture is all handmade and if it needs to be assembled, the master comes and does what is needed. If someone is interested, then I earn by playing in various online casinos from the site https://onlinecasinos367.com . They are really honest and will not leave anyone without a win.
In this regard, I think that I can not help you. I myself only recently realized all the superiority of wardrobes. Before that, they seemed too big and uncomfortable to me, but then I read the article https://thedesigninspiration.com/blog/advantages-of-sliding-wardrobe-doors and now I understand that this is the best solution in an apartment or house.
I would just like to thank everyone for the instructions, you saved me!
The instructions label attached to the rear of the Stag Minstrel wardrobe will only break it down partially into 2 upright boxes without the plinth or top. To break it down to flat panels you need to remove the doors, unscrew the side panels and then remove the stapled rear hardboard panels ( this can be done by lightly hitting from the inside with a mallet). Be careful to support the sides when you do this or they will fall inwards. Once the rear panels are removed the sides can be lifted out from the base. They may be lightly glued to the batten on the base. A firm tap from inside the wardrobe (at the base of the side) with a mallet should free them. To reassemble you will need to screw or pin the back panels to the sides as the Staples cannot be reused. It took about an hour each to disassemble a 2 door and 3 door model carefully for re-use. I did this alone but it would be easier and quicker as a 2 person job.
These are the instructions for a Stag Minstrel S150 double door wardrobe which I hope helps figuring out what goes where etc..
I've just noticed the photo isn't very clear on line, so here is a transcript of what it says.
Instructions for dismantling Stag Minstrel double wardrobe S150.
1. Remove shelf by sliding forward.
2. Remove hanging rods and shoe rail by sliding their end ferrules ( the circular bits the rods pass through) inwards and sliding the rods clear.
3. Remove the screws that pass through the lower wings of the top gussets into the end panel.
4. Close both doors, bolting the left hand door at the bottom only.
5. Remove the screws that pass through the carcase back into the top panel
6. Remove the screws which pass down through the top of the wardrobe into the end panels, and lift the top, complete with gussets and shelf supports, clear of the wardrobe.
7. Lay the wardrobe on its back, and remove the screws which pass upward through the front and back rails into the bottom panel.
Pull the plinth clear. The wardrobe will now divide into two halves.
NOTE : When reassembling the wardrobe make sure that
(a) the two halves of the wardrobe are located correctly together before fitting the plinth over the bottom location blocks ;
(b) all screws enter the holes bored for them.
