Why my refrigerator panel is showing er rf and the water dispenser doesn't work ?
I unplug the fridge and the panel goes back to normal for about 3 hours and then goes back to er rf everything else seems to work-the ice maker and freezer and fridge.
Causes of the Er rF Error Code
An Er rF error code, as we've mentioned, indicates that there's some kind of problem with the fridge's fan motor; specifically, that the fan motor isn't running when it should be.
Dec 16, 2021
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan
that controls the unit's ice production. If this problem occurs because
of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to
thaw may fix the issue. Call customer service if that doesn't work.
I have a LG refrigerator freezer side by side about 6 years old I fet a reading on the digital display FRZ -Er REF -Cr when I unplug the thing and replug it the display is back to normal after a few seconds it gives me the error readings fridge and freezer keep cold but ice and water dispenser doesn,t work HELP
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
This is an error code for the icemaker fan motor. If the control does not see a signal coming back from the fan motor you will get this error code. Please see the image below from the service manual that explains the ER IF error code.
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
I posted a similar problem with the er if code. I think I have isolated it down to the ice maker fan problem. It appears that the master unit is not getting the correct code from the ice maker fan. I managed to get rid of the problem by dumping the ice, turning the ice maker off (there is a switch next to the ice maker), and unplugging the unit for three minutes and plugging it back in. However, I am without an ice maker. But the problem has not returned and the rest of the unit seems to work normally.
