I try to install a fresh copy of windows xp, i had windows vista prior to this, and i boot from cd and after i get a message like .....inspecting harware configuration and a blank screen ........and nothing after ???
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software
problems. Hardware issues can also cause boot problems (i.e. bad hard
drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data
before making changes to Windows XP. Relax, if you follow these
instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your
computer's CD-ROM or DVD-ROM drive, and then restart your computer.
When the "Press any key to boot from CD" message appears on the screen,
press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following
"Windows Setup" screen, and your first option. Select "To set up Windows
XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You
will be asked to repair an existing XP installation, or install a fresh
copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
How to reinstall Windows XP operating system or installing fresh copy of Windows XP on your computer.
If your Windows XP operating system had problem due to corrupted files, viruses problem or you want to upgrade your system. This procedure will guide you in reinstalling your current Windows XP or installing fresh copy.
After this installing process, you need all your hardware drivers like Chipset Intel driver, LAN driver, Sound driver, WAN driver, Webcam driver and others for the computer to be fully operational. Otherwise, do not proceed on reinstalling you operating system if your do not have those hardware drivers.
CDROM drive is required for installing Windows XP. If you don't have in your notebook computer, use external CDROM drive to connect in your computer using a USB cable.
1. To start with, you need to back up your in blank CD all your important files before you begin installation produre because all the data will be wipe out.
2. When ready, start your computer and when booting press F2 to BIOS setting.
3. On BIOS menu, choose the BOOT setting and change the priority boot to CDROM, exit and save.
In some laptops, you can skip this BIOS setting process by repeatedly pressing F9 key or F10key when booting your computer and it will run boot priority on CD.
4. Once you exit from BIOS, you computer will reboot and a message will appear " Press any key to boot from CD", press any key to enter into WINDOWS XP SET UP.
5. Belows instruction messages will appear:
* To set up Windows XP now, press ENTER * To repair Windows XP installation using recovery console, press R * To quit set up without installing Windows XP, press F3
Press ENTER to initiate the installation.
6. You will go to Windows XP license agreement and press F8 to agree.
7. You will ask you if you want to REPAIR or REINSTALL the operating system. It will appear like this. Just press ESC to proceed.
A. To repair the selected Windows XP installation, press R. B. To continue installing fresh copy of Windows XP without repairing, press ESC.
From repairing your operating system, it will not removed all your files and other software installed in your computer including your hardware drivers installed. Just fixing the operating system.
For reinstalling the operating system, you need to back up all you files because it will wipe out all you datas in your computer.
8. After that, it ask you where partition you want to install the operating system. The message will display like this :
C : Partition1 [NTFS] D : Partition2 [NTFS] Unpartitioned Space
Use the directional key to navigate and choose C: Partition1 if you want reinstalling Windows XP and press enter.
If you want clean copy of Windows XP, you need to delete both partition by pressing L and install clean copy at Unpartitioned space. By these procedure, you will have C: drive only. D: Drive is delete.
9. After choosing the desire partition. this will appear :
* Format the partition using NTFS files system * Format the partition using the NFTS file
I suggest to choose the first line which is the quick format. The 2nd line take too much time to install the operating system. Press to initiate the installation and it will be finish and reboot automatically. PART OF WINDOWS INSTALLATION IS FINISHED.
If you had interrupted installation which is asking for certain driver file, your CD installer maybe damage which cause files to be unreadable. Try to replace the new Windows XP installer CD to proceed and until finished installing OS.
10. Once it reboots, this time do not boot from CD or do not press any key to go to PART2 OF WINDOWS XP INSTALLATION PROCESS.
11. On the opening, regional and laguage option will appear, jus click next.
12. The it will ask to type your name & organization. Put you name and company if any and click next
13. Then, it will ask for CD key and type the 25 character CD key and click next
14. Then it will ask for computer name. You can change or leave it and click next.
15. Then, set your date and time zone and click next.
16. Then, it will ask you for workgroup and computer domain, just leave it and click next.
17. Now wait until the installation process end and it will again restart automatically.
18. Again, do not boot from CD and display setting will appear. Just click OK.
19. welcom to Microsoft Windows screen will appear. Just click next.
20. Helps protect your PC will appear and choose Turn on Automatic Updates ( Only if you install genuine Windows XP). Otherwise, I suggest to choose "Not right not" if you are installing copy only of Windows XP.
21. Who will use this computer message will appear. Just type your name on the first box and click next.
Also for your reference, here is the video for your convenient .
A thank you message will appear, Just click next and it is finished.
I hope it helps you and thank you for using FixYa !
For repairing the operating system here is the blog as other want it.
As per others demand, here is the video for Windows 7 and Windows Vista Operating system
Before beginning please note the following:
All your data will be erased by the end of this process.
Also I recommend to switch to Windows 7 (instead of XP) as they are far better and faster than Vista and XP. If you can switch your XP for Windows 7 then you should do that.
However the decision is yours.
Nothing else should be done except to backup your data.
Then, insert the XP disc in your dvd drive and restart your computer. When the message "Press any key to boot from CD" appears press enter.
When the XP setup loads, select to format your hard drive and install a fresh copy of XP. Follow the on screen instructions and you will have XP on your system in about 30-45 minutes.
You would need a operating sytem cd/dvd (windows xp\windows 7) and a windows COA key. Select your bios to boot from cd\dvd player. Insert the new cd of a different operating system into the drive and restart the computer. It should say press any key to start from cd. Press any key and proceed. You will get to an option to format and install. Format the drive Probably marked C:. This will wipe out the drive and install a fresh copy of whatever OS cd you booted from. Good Luck.
Please check your setup config to be sure of the boot order. Should be CD-ROM, Hard drive, other external media source (USB). Once you have the boot sequence set, retry the windows CD.
