2008 Ford Escape Logo
A
Anonymous Posted on Mar 18, 2015
I have 08 ford escape when I try to scan it said no communication
Jeff Armer
Level 3:
  • Ford Master 15,575 Answers
  • Posted on Mar 19, 2015
Jeff Armer
Ford Master
Level 3:
Answers
15575
Questions
Helped
7111809
Points
73899
Do you know about communication networks or serial data communications on vehicles , these let the scan tool communicate with the different modules on the vehicle ! Newer vehicles have several, PCM - powertrain control module , Anti-theft module , Air bags , antilock brakes , Body control module or in the case of ford a smart junction box . an some others !
Communications Network Vehicle communication utilizes both International Standards Organization (ISO) 9141 and controller area network (CAN) communications. ISO 9141 is used for diagnostic use only, and CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking, is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
The vehicle has 3 module communication networks:
  • ISO 9141
  • Medium speed (MS) CAN
  • High speed (HS) CAN
All 3 networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on the 3 networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
HS-CAN Network Operation
The HS-CAN network communicates using bussed messages. The HS-CAN network uses an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
The HS-CAN is a high speed communication network used for the following modules:
  • ABS module
  • 4WD control module (if equipped)
  • Instrument cluster
  • PCM
  • MS-CAN Network Operation
    The MS-CAN network communicates using bussed messages. The MS-CAN has an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
    The MS-CAN is a medium speed communication network used for the following modules:
    • SJB
    HS-CAN Network
  • What type of scan tool are you using ? or are you using a code reader ?
  • What
Computer No Communication Troubleshooting by Wells Saturn Toyota Echo No Communication Case Study
1helpful
Power steering assist fault how to fix it?
Yes, it is electronic! check fuses and check for codes.
https://www.google.com/search?q=08+Ford+Escape+xlt+my+power+steering
Code u2023 on 2005 ford escape
U2023 External Node Fault DTC ABS Module REFER to Section 418-00 . U2023 Fault Received From External Node SJB REFER to Section 418-00 .
Do you know what U codes are about ? Which module did you find this code in ? Does scan tool communicate with all the module's on the vehicle .
Do you know what the problem may be?
Ford Focus cutting out and losing engine power, mileometer going ...
www.rac.co.uk > ... > Technical and Maintenance Questions
RAC Limited 10 posts - ‎6 authors
About five weeks ago, after driving for 1/2 mile, my car cut out with no warninh ... 26-08-11, 12:04 #1 ... I have a 51 Ford Focus 1.6 petrol, about 77000 miles on the clock. ... to check it wasn't anything I was doing, and whilst it wasn't half as bad, he did ... My main concern is the power failures causing the car to actually cut out ...Missing: kuga ‎11600 ‎stutters
Petrol in a diesel car - Guide and Videos - Auto Fuel Fix
My Escape is sputtering / losing power. - Ford Forums - Mustang ...www.fordforums.com/f59/my-escape-sputtering-losing-power-191329/Old 07-08-13, 07:22 PM Thread Starter. Escape2009. Registered User. Join Date: Jul 2013. Posts: 5. My Escape is sputtering / losing power.Engine power loss and sputtering - CarGurus
U 1900 on a 2005 ford escape how can i fix it.
The U1900 is a Communication Problem in the
vehicles CAN Network
Like having your internet go down or computer
& the printer not talking to each other
Need a Professional Scan Tool to diagnose
Don't need a dealer-- unless the shops you chose
are too lazy to learn the technology
Where is the fuel pump driver module on a 2008 Ford Escape
on the bottom of the car near the gas tank, looks like a small square box with wires connected to it.
Speaker Wire Colors on an 08 Escape?
This for base radio system, non-hybrid, 08 ford escape.
3helpful
Ford Diagnostic Tool
There are a couple of decisions you will need to make before looking at them. How much to you want to be able to do? Do you want to be able to just retrieve trouble codes? Do you want to be able to communicate with all of the modules on the vehicle? Do you want data logger capability so you can monitor data to help pin-point problems?
Most cheap scan tools only communicate with the PCM(powertrain control module) but for example your 2006 explorer has a HSC(high speed can network) and a MSC(medium speed can network). The HSC depending on options may have 8 modules and the MSC may have 9 modules depending on options.
The Escape uses 2 networks called SCP(standard corporate protocal) and a ISO( international standards organization ) and it has 5 modules.
So you would have to make sure that what ever scan tool you are looking at can communicate with these types of networks.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
