SOURCE: I am not sure what I need to do to update my GPS.
I am unable to buy an Australia map, you have all my detail on register but it won't let me purchase.Regards Bill Rossiter
SOURCE: I need assembly instructions for a wilson and fish...
I didn't have my instructions either, but I finally figured it out. I do the top first. I'm 5'2" and I put it up by myself and this works for me. The leg connections are 6&5 with 6 being on the bottom with little holes near the base stand and 5 being on top. Add the corner connectors and side connectors to tops of 5. Out from the corner connectors add your 7's. Out from the side connectors the 10's for the long side and 8's for the short side. For the top corners add 4 then 3(it is that funky looking rod). In the middle connector add the 11& 12(this will be for the long sides).You will connect corner and sides with 1 (make sure to put the sliding connector on the rod with the Y's at the ends. On the top, top add the last rod. I think you'll be able to figure out how the canopy drapes. I hope I've given the right directions for yours. I put mine up yesterday.
SOURCE: I purchased this drill almost
Hello Blreid, to get the chuck off, you will need to be able to close the chuck. If this means using 2 plumber's wrenches, then so be it. Follow the directions below, and let me know if it works.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting. Remove the battery! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you, and if not, explain what is happening.
SOURCE: Need assembly instructions for a 10x12 Wilson
I looked for hours on the internet trying to find this.
Hope this saves you some time. The manual can be downloaded here.
You can show your appreciation by becoming my scribd follower so you can get all my do it yourself posts.
http://www.scribd.com/doc/55393964/Monterey-Gazebo
thanks
Bill Kibbe
SOURCE: Bought this a number of years ago. Lost my info
If you contact Garmin support and give your name and serial number off the unit they will be able to help you. I have attached the link below to the Garmin support.
Thanks for using FixYa
http://www.garmin.com/garmin/cms/us/support/supportcontact
