Tablets & eReaders Logo
J
Janine Hayward Posted on Mar 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I convert a wireless wi fi kindle to my pc. I do not have access to wi fi.
I cannot use my Kindle as I do not have Wi Fi .Is there a way around it.
ka4iup
Level 3:
  • Tablets & eR... Master 4,062 Answers
  • Posted on Mar 03, 2015
ka4iup
Level 3:
Answers
4062
Questions
0
Helped
1096841
Points
51404
Not sure what you are asking. If you have internet service, you could purchase and install a cheap wi-fi router after the modem. This will provide you with local wi-fi service, which you can use with your Kindle. Just follow the instructions for the router to properly set up and secure.
2answers
I can't access the kindle store
Are you out of your usual wi-fi area? You may need to go back and check wi-fi settings and set up again.
From Home or any Settings screen, view the wireless indicators at the upper right corner of your Kindle. While reading, tap the top of the screen to view the wireless indicators.
Wireless Indicator Description Your Kindle is connected to 3G. This may also say EDGE or GPRS.
Note: For 3G enabled devices only Your Kindle is connected to a Wi-Fi network and has a strong signal. The Wi-Fi symbol appears when in range of a trusted Wi-Fi network.
Lost Wi-Fi on my kindle
You don't give any details. Do you mean you don't have any Wi-Fi at all? Go to the Settings Menu, Select the Wireless & VPN option and see if you are in Airplane mode, if you are turn that off. Then select Wi-Fi. See if Wi-Fi is turned on. If it's not turn it on. There should be a list of available Wi-Fi routers. If one is not selected select one that is open or that you have the password to. If none are open or they are locked and you don't have a password, you'll need to get a password for one, or install your own Wi-Fi router.
How do I connect to the kindle store my kindle will not connect so I may download kindle books?
To connect to the Kindle Store your device must have either a wi-fi connection to the Internet or a 3G Whispersynch connection via a telecom. Some Kindles come with the 3G and some don't. The ones that don't require a Wi-Fi connection.
So, if you have Wi-Fi access the turn off Airplane mode in Settings and enter the Wi-Fi password to your router. If you are using public Wi-Fi such as at McDonalds you might have to
use the experimental browser in setting to be able to click the *accept terms* button or you will not have access even if connected.
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
I can not or do not have a password for the sky wifi how do i get it
If the sky wi-fi is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be the same as you have selected on the Kindle in confirmation you are connecting to the correct network.
If the sky wi-fi is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
1helpful
I do not have wireless at home. Received the 3g version of kindle for christmas. It worked all this time. Today, it will not connect. Sees all sorts of wireless connections which are all password...
You are mixing up two things: 3G and Wi-Fi.
3G is a mobile phone data service, supported by selected Kindle devices. Your Kindle 3 3G has a SIM card built inside, just like the fingernail-size chips you put into a mobile phone. Amazon set up contracts with phone service providers in many countries so you can use it to download books to your Kindle at no extra costs for you other than the higher price of Kindle 3 3G compared to the non-3G version. You do not need any extra hardware for this to work, and it will work in most places of the world. This is the guarantee you were promised.
Wi-Fi is a wireless communication standard all Kindle devices support. While most hotels, airports and some restaurants provide free Wi-Fi access for guests, you need your own WLAN router at your home, and pay for your own broadband internet service. The "all sorts of wireless connections which are all password protected" belong to your neighbors and they are password protected so that nobody can take a free ride on the service they pay for.
You can tell the connection status of your Kindle from symbols in in the status bar, at the top right of the screen:
  • If it shows "OFF", wireless connectivity is deactivated and you cannot access the internet from your Kindle, or download books.
  • If it shows "Wi-Fi", the Kindle is connected to a Wi-Fi network. The five bars right of the symbol represent the connection's signal strength, the more bars are black, the better.
  • If it shows "3G", you are connected via 3G mobile data service. The bars right of this symbol refer to mobile phone service signal strength, much like a mobile phone would show you.
If you do not have internet connection with wireless LAN at home, you need to set up your Kindle to use the 3G service. This is the default setting when the device is delivered to you, and I believe it worked until you or somebody else inadvertently changed the configuration.
Follow this step-by-step procedure:
  1. Switch on your Kindle.
  2. Press the "Home" button.
  3. Check the status bar. Does it show the "3G" symbol? If yes, how about signal strength? If you are somehow blocked from mobile phone antennas in your area, signal strength will be low and the Kindle will not have internet access. Move around and see if it becomes better.
  4. Does it show the "OFF" symbol? If yes, press the "Menu" button. A menu of commands should open. Use the four-way button just below "Menu" to underline the top-most option "Turn Wireless On" and press the center of the four-way. The menu list will close, and after a moment Kindle will try to connect to the internet.
  5. Does it show the "Wi-Fi" symbol? If yes, I assume you accidentally connected to a neighbor's Wi-Fi network and its firewall protected, or is too far away to use it. In this case, press the "Menu" button to open the command menu. Use the four-way button just below "Menu" to underline "Settings", second option from the bottom, and press the center of of the four-way. The settings menu will open. Use the four-way button to navigate down to "Wi-Fi Settings" (the text "view" must be underlined) and press the center of the four-way. The list of Wi-Fi networks open. Navigate down using the four-way to any network with the text "forget" on it and press the center of the four-way.
Please let me know if you encounter problems in following these instructions, and I'll try to assist you further.
2answers
I've only found 1 wi fi network on my kindle and it asks for a password, where do I get the password
From the owner of the Wi-Fi network.The password is usually set up in a network router to limit wireless access to authorized people.
If you have no idea what I am talking about, your Kindle probably located a neighbour's wireless internet access point and you cannot use it without his permission.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
