During the first cleaning and the second cleaning cycle, a lot of water (250ml each time) came on the floor and drops are leaking from the front door left inside corner continuously... It is the first time today this happens. Don't have any idea...???
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out
with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the lower
back of the freezer.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
