My sharp MX-C311 shows maintenance required Code TA
Hi, TA code refers to maintenance all counter has reached its specified limit. This usually means all the consumable parts have reached the end of their service life. If you have a maintenance contract with a Sharp dealer then they should replace all the units that require replacing & reset the maintenance counters for you, if you don't then, if the copy quality is still ok, you should be able to continue to use the machine as normal.
Hope this helps.
Dave.
