It cant be a difficult thing to set a digital clock on a stove
You could try:
- For hours, pressing the first knob (their labels will give you a clue) inwards and turn clockwise while still pushing it in, when the right time is showing on the display, release the button.
- Same procedure for other button may be the minutes
Helpful? Please let us all know, it could be useful for someone else.
Good luck with it. Chris
Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
